[Gdal-dev] Re: Finding the row and column in a Raster that includes a point
Carlos A. Rueda carueda at ucdavis.edu
Wed Feb 9 02:56:13 EST 2005
Donald,
You may want to look at:
    http://gdal.org/gdal_building.html#largefiles
good luck,
carlos
Johnson, Donald W MVK Contractor wrote:
> Also does GDAL have issues with large files? RasterIO returns CPL_Failure
> when I try to read and ESRI grid that is 3.7 gigs. The code works fine on
> smaller surfaces.
> Thank You
> Donald J
