[Gdal-dev] georeferencing aster level 2 data
Frank Warmerdam fwarmerdam at gmail.com
Tue Feb 15 10:30:08 EST 2005
On Tue, 15 Feb 2005 16:09:08 +0100, Vincent Schut <vincent at ecovla.nl> wrote:
> Hi all,
> I thought that gdalwarp was able to georeference aster level 2 data (the
> ast_09 on demand data from the eos data gateway), however, whatever I try, I
> can't get gdalwarp to recognize the corner coordinates (get an error saying
> that no gcp's were found). Any idea? Their are UPPERLEFT, UPPERRIGHT,
> LOWERLEFT and LOWERRIGHT metadata items in the hdf files (.hdf0 and .hdf1).
> Of couse I can write a script that extract the corner coordinates, attaches
> them as gcp's to a vrt file, and warp this file, but if I could do this in
> one run using gdalwarp it would be much nicer.
Vincent,
If you point me to a sample file I can download, I can look at
automatically translating the corners into GCPs.  I have recently
added automatic recognision for georeferencing data from other
specific products in GDALs HDF driver.
Best regards,
