[Gdal-dev] man pages mixed
Maciek Sieczka werchowyna at pf.pl
Thu Feb 17 17:56:23 EST 2005
On Wed, Feb 02, 2005 at 12:23:20PM +0100, Maciek Sieczka wrote:
>> Hi Frank
>> On my gdal-cvs-20050115 built from source the man pages for gdal_contour
>> and gdaltindex are mixed into one - /usr/local/man/man1/gdaltindex.1.bz2.
>> Is it GDAL's fault?
>It it the fault of a wront doxygen configuration for the creation of
>manpages.
>Frank, could you please apply the following patch to the gdal-cvs?
>It should fix the problem
>Many thanks,
> Silke
Silke
Now (gdal-cvs-20050215) gdal_contour man is missing for good!
> (and additionally fix the case that no pct2rgb.py-manpage is created).
No sign of pct2rgb.py man though, hmm.
BTW - is ogr_utilities man supposed to be empty - the way it is now?
Maciek
>-- gdal-1.2.5.orig/gcore/gdal_utilities.dox
>++ gdal-1.2.5/gcore/gdal_utilities.dox
>@ -578,7 +578,8 @@
>\if man
>\section wauthor AUTHOR
> Frank Warmerdam <warmerdam at pobox.com>
>+/*! \page gdal_contour
>builds vector contour lines from a raster elevation model
> \section isynopsis SYNOPSIS
>\endif
>@@ -702,6 +703,8 @@
> \if man
> \section iauthor AUTHOR
>+/*! \page pct2rgb.py
 >converts an image into a pseudo-colored image
 >\section rsynopsis SYNOPSIS
