[Gdal-dev] MrSID, GDAL & Mapserver
Yar numerous at gmail.com
Thu Feb 17 19:34:15 EST 2005
Thank you Frank and Martin,
I got gdalinfo to work, I still cannot display my MrSID, and I'm getting the
same error message in IE.
I do get the following info when I run gdalinfo on my file:
C:\ITS\GDAL\125\bin>gdalinfo
Usage: gdalinfo [--help-general] [-mm] [-nogcp] [-nomd] datasetname
C:\ITS\GDAL\125\bin>gdalinfo --format mrsid
Format Details:
  Short Name: MrSID
  Long Name: Multi-resolution Seamless Image Database (MrSID)
  Help Topic: frmt_mrsid.html
C:\ITS\GDAL\125\bin>gdalinfo C:\its\Apache2\htdocs\statewide\shape_files\mrsid\1
4_1_1.sid
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
Size is 24066, 25370
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4269"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-99],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","26914"]]
Origin = (653334.000000,3916062.000000)
Pixel Size = (0.30000000,-0.30000000)
Metadata:
  GEOTIFF_CHAR__GTModelTypeGeoKey=ModelTypeProjected
  GEOTIFF_CHAR__GTRasterTypeGeoKey=RasterPixelIsArea
  GEOTIFF_CHAR__ProjectedCSTypeGeoKey=PCS_NAD83_UTM_zone_14N
  GEOTIFF_CHAR__ProjLinearUnitsGeoKey=Linear_Meter
  GEOTIFF_NUM__1024__GTModelTypeGeoKey=1
  GEOTIFF_NUM__1025__GTRasterTypeGeoKey=1
  GEOTIFF_NUM__1026__GTCitationGeoKey=IMAGINE GeoTIFF Support
Copyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: egtf.c $ $Revision: 1.9.2.4 $ $Date: 2002/01/24 16:43:13Z $
Projection Name = NAD_1983_UTM_Zone_14N
Units = meters
GeoTIFF Units = meters
  GEOTIFF_NUM__3072__ProjectedCSTypeGeoKey=26914
  GEOTIFF_NUM__3073__PCSCitationGeoKey=IMAGINE GeoTIFF Support
UTM Zone 14N
Ellipsoid = GRS 1980
Datum = NAD83
  GEOTIFF_NUM__3076__ProjLinearUnitsGeoKey=9001
  IMAGE__BITS_PER_SAMPLE=8
  IMAGE__COLOR_SCHEME=0
  IMAGE__COMPRESSION_BLOCK_SIZE=512
  IMAGE__COMPRESSION_GAMMA=2.000000
  IMAGE__COMPRESSION_NLEV=9
  IMAGE__COMPRESSION_VERSION=2,0,0
  IMAGE__COMPRESSION_WEIGHT=2.000000
  IMAGE__CREATION_DATE=Fri Apr 16 18:34:39 2004
  IMAGE__DATA_TYPE=0
  IMAGE__DYNAMIC_RANGE_LEVEL=127.500000
  IMAGE__DYNAMIC_RANGE_WINDOW=256.000000
  IMAGE__HEIGHT=25370
  IMAGE__INPUT_FILE_SIZE=1831867219.000000
  IMAGE__INPUT_FORMAT=GeoTIFF
  IMAGE__INPUT_NAME=I:\OKC_High_Res\14_1_area01\ochipdata.tif
  IMAGE__TARGET_COMPRESSION_RATIO=20.000000
  IMAGE__WIDTH=24066
  IMAGE__XY_ORIGIN=653334.150000,3916061.850000
  IMAGE__X_RESOLUTION=0.300000
  IMAGE__Y_RESOLUTION=0.300000
Corner Coordinates:
Upper Left  (  653334.000, 3916062.000) ( 97d18'43.12"W, 35d22'34.01"N)
Lower Left  (  653334.000, 3908451.000) ( 97d18'48.26"W, 35d18'27.06"N)
Upper Right (  660553.800, 3916062.000) ( 97d13'57.11"W, 35d22'29.92"N)
Lower Right (  660553.800, 3908451.000) ( 97d14'2.49"W, 35d18'22.98"N)
Center      (  656943.900, 3912256.500) ( 97d16'22.74"W, 35d20'28.52"N)
Band 1 Block=24066x64 Type=Byte, ColorInterp=Red
  Overviews: 12033x12685, 6017x6343, 3009x3172, 1505x1586, 753x793, 377x397, 189
x199, 95x100
Band 2 Block=24066x64 Type=Byte, ColorInterp=Green
x199, 95x100
Band 3 Block=24066x64 Type=Byte, ColorInterp=Blue
x199, 95x100
Any hints on what I should try next to display the MrSID, could it be a layer
problem?
Thank you!
Yar
