[Gdal-dev] Trouble importing Arc 8.3 projection file into OGR SRS
Frank Warmerdam fwarmerdam at gmail.com
Thu Feb 24 15:23:43 EST 2005
On Thu, 24 Feb 2005 14:54:56 -0500, William Lyons
<wlyons at prologic-inc.com> wrote:
> Hello Frank, and List,
> I'm attempting to import the Arc 8.3 projection file below into an
> OGRSpatialReference using SetFromUserInput().
> But, I get OGRERR_CORRUPT_DATA as a result.  So, my questions are:  Is this
> supposed to happen? And,
> If so, is there some way to import it?
William,
I tried the file with testepsg, and it seemed to work fine.  Testepsg
(manually buildable in gdal/ogr) uses SetFromUserInput().
I don't see anything odd about the file in question nor any reason
it would fail.  If possible, you might want to trace through the code and
see what is going wrong.
Best regards,
