[Gdal-dev] RasterIO()
gal05 senkum_d at yahoo.com
Sat Feb 19 22:49:28 EST 2005
Hai Frank,
  I am attaching a program which is meant to convert a raw binary image file
into a GTiff file. If i try to open the output file using ENVI, the image is
not properly displayed. I dont know what could be wrong. And i am trying to
set projection "WGS84", i tried using SetWellKnowGS() but it doesn't support.
So i am passing the data to the setprojection(). Is that right? And whats the
problem with the RasterIO() that used in the program to write the file.
Could u help me to modify the program to make it work and display the Gtiff
image properly.
Thanks in advance...
-Gal05
#include "gdal_priv.h"
#include "cpl_string.h"
#include <ogr_spatialref.h>
#include <iostream.h>
#include <cstring>
/* The program is to add a GeoTIFF header to a binary image and output a
GeoTIFF file
     Inputs :  filename x y
 where filename  : the name of the binary image to be added with GeoTIFF
header
 x         : numbers of columns for the input image (in this case 21000)
 y         : numbers of rows for the input image    (in this case 12500)
/**Reading the input file name, column and row values    ****/
        int main(int argc, char **argv)
           char *src = argv[1];
           int Xvalue=atoi(argv[2]); //read the X and Y value from command line
           int Yvalue=atoi(argv[3]);
/*     construct the input file name and store the source name in the array  */
        // normally input file name has an extension of .img
           char srcFile[100]; //array for source file name
           char dstFile[105]; //array for destination file name
           int i=0;
              while(src[i]!='\0')
                 srcFile[i]=src[i]; //reading the input name
                    dstFile[i]=src[i];
                    i++;
           srcFile[i]='\0';
           dstFile[i]='\0';
       // to add the .tif extension to the output file name
          char ext[3]={'f','i','t'};
          int l=0;
             for(int k=i-1; k>=i-3; k--)
                   dstFile[k]=ext[l];
                   l++;
          cout <<"\nDestination file name  :"<<dstFile<<"\n";
/**************** construct an output GeoTiff image file with
geotransformation and projection ***********/
       //adfGeoTransform[5] array value
        double  adfGeoTransform[6]={-
2624999.963000,250.000000,0.000000,1006701.788000,0.000000,-250.000000};
      // definitions for using GDAL library
        char **papszOptions = NULL;
        GDALDataset *poDstDS;
        const char *pszFormat = "GTiff";
        GDALDriver *poDriver;
        char **papszMetadata;
        GDALAllRegister();                 //Register All Drivers
        //Set the Driver using DriverManager
        poDriver = GetGDALDriverManager()->GetDriverByName(pszFormat);
        //Create a new dataset with this driver
        poDstDS  = poDriver->Create(dstFile, Xvalue, Yvalue, 1, GDT_Byte,
papszOptions );
      //SetProjection data
char *projstring ="PROJCS[\"IMAGINE GeoTIFF Support Copyright 1991 - 2001 by
ERDAS, Inc. All Rights
Reserved @(#)$RCSfile: egtf.c $ $Revision: 1.6.1.4 $ $Date: 2001/04/23
14:58:04Z $ Projection Name = Lambert
Azimuthal Equal-ar\",GEOGCS[\"WGS84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84
\",6378137,298.2572235629972,AUTHORITY[\"EPSG\",\"$
/***************** adding the geotransform values and the projection details
on the output file *********************/
        poDstDS->SetGeoTransform( adfGeoTransform );
        GDALRasterBand *poBand;
        poDstDS->SetProjection( projstring );
        printf( "\n\nProjection is %s\n",projstring );
 CPLFree( projstring );
        poBand = poDstDS->GetRasterBand(1);
        cout<<"\nsuccessful completion of passing geotransform and projection
info\n";//
/*********************  Reading binary image file row data and writing to the
ouput file ***************************/
        FILE *inFile;
        inFile = fopen(srcFile, "rb");                  // open the input file
in Read Binary mode
        float * rowData = (float *)calloc(Xvalue, 1);   // to assign the
memory for each row data
        cout <<"\nreading file..\n"<<sizeof(float)<<"\n";
            for(int j=0;j<Yvalue;j++)
                  fread(rowData,sizeof(float),Xvalue, inFile);  // reading the
row data
                  poBand->RasterIO( GF_Write, 0, j, Xvalue, 1,  rowData,
Xvalue, 1, GDT_Byte, 0, 0 ); //write data
        cout<<"\ndestination file written!\n";
        free(rowData);                                  // free memory
        fclose(inFile);                                 // close input file
        delete poDstDS;
   return 0;
