[Gdal-dev] Shapefile spatial indexing
Frank Warmerdam fwarmerdam at gmail.com
Tue Jan 4 10:39:25 EST 2005
On Tue, 4 Jan 2005 16:21:13 +0100 (CET), bartvde at xs4all.nl
<bartvde at xs4all.nl> wrote:
> Hi Frank,
> great! Can the spatial indexes also be created using shptree or must one
> use the SQL CREATE SPATIAL INDEX syntax?
Bart,
You can create them with shptree as well.  One of my objectives
was to ensure the format was 100% compatible between mapserver
and ogr.  I also adapted Steve's code for reading, writing and
scanning them.
Best regards,
