[Gdal-dev] [Fwd: Problems installing GDAL 1.2.5]
Andrey Kiselev dron at ak4719.spb.edu
Fri Jan 7 12:45:30 EST 2005
On Thu, Jan 06, 2005 at 01:30:17PM -0700, William Hudspeth wrote:
> I am having problems installing GDAL 1.2.5 on Redhat 9. The problem may
> involve the HDF4 installation (see output below). I had no problems
> installing HDF4 and used the following configure options:
> ./configure --with-hdf4=/usr/local/include --with-libgrass=/usr/local/lib
> These options point to hdf4.h and libgrass5.a (etc...) in the respective
> directories.
> OUTPUT
> gctp_wrap.c:1:25: ogr_srs_api.h: No such file or directory
I did a fix for that in CVS. Please, try the CVS snapshot and report in
case of further problems.
Best regards,
Andrey
Andrey V. Kiselev
Home phone:  +7 812 5970603  ICQ# 26871517
