[Gdal-dev] setting "thematic" flag for IMG
Frank Warmerdam fwarmerdam at gmail.com
Mon Jan 10 13:26:10 EST 2005
On Mon, 10 Jan 2005 11:31:58 -0500, Stephane Routelous <route at cae.com> wrote:
> Hi Frank,
> thanks a lot for your answer.
> If it is not too hard for you, it will be good if I can get access to the
> metadata setting quite quickly (today or tomorrow seems very good).
> If you don't have time, I can try to dig into the code to make it, but I
> never touched or used the metadata mecanism.
Stephane,
I have committed support for getting and setting the layerType
value for bands via the LAYER_TYPE metadata entry.   I have
also committed a bunch of code related writing compressed
imagine files supplied by Sam Gillingham.  Let me know if you
have any problems.
Best regards,
