[Gdal-dev] Compilation problem with 1.2.5
Piero Cavalieri pierocavalieri at tiscali.it
Wed Jan 12 19:03:40 EST 2005
Frank Warmerdam wrote:
>On Wed, 12 Jan 2005 00:50:13 +0100, Piero Cavalieri
><pierocavalieri at tiscali.it> wrote:
>>Hi all,
>>I still have a compilation problem with version 1.2.5
>>Error messages are about headers not found.
>>This is due because when I run ./configure the
>>file GDALmake.opt is created, but it's empty.
>>This also happens with 1.2.4 version, but not with
>>1.2.3 and previous versions.
>>Could someone give me some suggestion on what looking for
>>to solve this problem?
>Piero,
>This sounds very much like the MySQL 3.x problem.
>Just configure with --without-mysql to work around this.
>This problem is fixed in CVS.
>Best regards,
Ok, configuring with
--without-mysql
solved the problem.
Thanks
       Piero
