[Gdal-dev] NAD83 Fipszone 903 to WGS84 Error
Frank Warmerdam fwarmerdam at gmail.com
Thu Jan 13 00:20:04 EST 2005
On Tue, 4 Jan 2005 16:30:16 +0000 (UTC), Eric Lindahl <eric at 21csi.com> wrote:
> Hi,
> I attempted to fix the PRJ.ADF import that didn't recognize the FIPSZONE
> key word.
Eric,
OK, i have applied a variation on your FIPSZONE
support, and also corrected the problem you encountered
with NAD83 state plane zones with feet units.   The
changes are in CVS.   If it is convenient for you, i would
appreciate it if you could grab the daily snapshot tomorrow
and try out gdalinfo on your dataset to verify the corners
are right in lat/long now.
Best regards,
