[Gdal-dev] GDAL & OpenEV / MFC
James Goodwin James.Goodwin at sea.co.uk
Fri Jan 14 10:11:19 EST 2005
I've downloaded the GDAL library and been successfully built it and loaded an S-57 file.  I've also downloaded the OpenEV code for displaying S-57 files.
However, I'd like to use GDAL, OpenGL and the MFC libraries (not GTK) to do my coding!
Has anyone taken this path already?  If so, is the any free code available?
James
________________________________________________________________________
This email, and any attachment, may contain information that is confidential and/or subject to copyright. The recipient of any email from SEA shall not forward any message or attachment to any third party without prior consent from SEA. Although SEA uses all reasonable endeavours to prevent the transmission of known viruses, SEA shall accept no liability for any damage to systems or loss of or corruption of data caused by any virus inadvertently transmitted. SEA reserves the right to monitor all incoming and outgoing email for any lawful purpose; this is clearly stated in the SEA policy - The Use of Computer and Telephony Equipment By Staff. The contents of this email do not give rise to any binding legal obligation upon SEA unless a separate confirmation is sent on headed stationery, either in hardcopy or by email, as an attachment. If an email is to create a binding obligation on SEA, through the use of an attachment, then this shall be clearly stated in the body text. Anyone dealing with SEA by email who objects to any of these terms should refer their concerns to the Business Systems Manager through the contact listed above.
