[Gdal-dev] using the GDAL.open in python
francesco francesco.pirotti at unipd.it
Mon Jan 24 12:43:49 EST 2005
Hello,
I have a file from ASTER satellite which is called "001" and has a metafile
called "001.met":  if I access to that file with the gdalinfo or
gdaltranslate utility everything works just fine, but when I use python
coding my own program, the
gdal.open(file,  GA_ReadOnly )
returns None and the error message is that the file 001 is not recognized
as a supported file format.  How can that be?
I must say that it is a file from ASTER satellite with 15 subimages.
Any ideas? Thanks.
Cheers,
Francesco Pirotti
