[Gdal-dev] A typo in hfadataset.cpp
Yang, Zhiqiang zhiqiang.yang at oregonstate.edu
Fri Jan 28 12:20:14 EST 2005
It seems like that there are two typos in hfadataset.cpp. The word
"Azimuthal" was typed as "Azitmuthal" on line 1241 and 1250. As a
result, if you set a projection to to "Lambert Azimuthal Equal-area" or
"Azimuthal Equidistant", the resulting image will not be valid in
projection.
yang
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050128/5b4233c7/attachment.html
