[Gdal-dev] nodata error with gdalwarp and -rcs option
vincent at ecovla.nl vincent at ecovla.nl
Mon Jul 11 06:59:01 EDT 2005
Frank, folks,
I found an error with gdalwarp. It appears that when the -rcs resampling
option is used in combination with -srcnodata and -dstnodata, the nodata
pixels still get interpolated. When another resampling option is used,
the nodata pixels are (correctly) retained as such in the output image.
Regards,
Vincent.
