[Gdal-dev] Autodesk DWF library
Paul Selormey paul at toolscenter.org
Tue Jul 12 20:21:07 EDT 2005
It is simply an alternative to PDF. It started as Whip (may be
to whip PDF!).
If there should be a support for Autodesk formats, obviously it
should be DXF and DWG. May be one day Autodesk will sponsor GDAL
to add the support for their RealDWG library.
Best regards,
Paul.
> -----Original Message-----
> From: gdal-dev-bounces at xserve.flids.com
> [mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Frank
> Warmerdam
> Sent: Wednesday, July 13, 2005 3:54 AM
> To: Kralidis,Tom [Burlington]
> Cc: gdal-dev at xserve.flids.com
> Subject: Re: [Gdal-dev] Autodesk DWF library
> On 7/10/05, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > FYI -- wonder if this would be useful for inclusion as an OGR
> > supported format?
> > ..Tom
> > http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=5520675
> Tom,
> What isn't clear to me is how much interest there is in DWF support.
> Reading over the DWF FAQ I am concerned that it isn't a very
> accurate format.  I also *suspect* the original data is
> pretty dumbed down for display purposes though I don't know
> that for a fact.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
