[Gdal-dev] is that ecw format is really supported?
Bart van den Eijnden bartvde at xs4all.nl
Sun Jul 17 09:46:04 EDT 2005
Tileindexes are always shapefiles, and they only contain references to
data (in the LOCATION field of the dbf), not the actual data.
Did you compile GDAL against the ECW SDK? Otherwise it can't read ECW
files. Or which binary version are you using?
Best regards,
Bart
On Sun, 17 Jul 2005 14:39:20 +0200, cout m <coutm at yahoo.fr> wrote:
> hi list,
> I would like to know if the ecw format is really
> supported by gdal. Because i'm trying to make à
> tileindex with gdaltindex and finally  I obtain  a
> .shp, a .dbf and a .shx without data.
> I write : "gdaltindex ./index1.shp ./raster/*.ecw" in
> debian Konsol
> But, when i made a tileindex with GTiff, it run fine.
> have you got an idea about this problem?
> Marie Coutard
> ___________________________________________________________________________
> Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo!
> Messenger
> Téléchargez cette version sur http://fr.messenger.yahoo.com
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
