[Gdal-dev] Trouble with ECW support
Chris Hodgson chodgson at refractions.net
Mon Jul 18 14:03:04 EDT 2005
I'm trying to get gdal working with the ERMapper ECW library. I managed
to determine that their latest version, 3.2beta is not yet supported, so
I switched to trying with 3.1. I was able to get the ecw library to
compile without any particular hacks or tricks... however, in order to
get the types to be included properly when I was compiling gdal with ecw
support, I had to put
#define POSIX
#define LINUX
at the top of Source/include/NCSTypes.h in the ECW librray source.
Otherwise, it when I was compiling gdal, it complained about missing
types. I think this was the right thing to do? Anyways, it all compiles
afterwards.
Then I compress several geotiffs into ECW using something like:
gdal_translate -of ECW -co 'TARGET=10' input.tif output.ecw
then I build a tile index of them using something like:
gdaltindex tiles *.ecw
then I use it in mapserver using something like:
   LAYER
     DEBUG ON
     NAME "ortho_collage"
     TYPE RASTER
     STATUS ON
     TILEINDEX "tiles.shp"
     TILEITEM "Location"
     PROJECTION
       "init=epsg:42102"
     END
     MAXSCALE 75000
   END
And all I can get is the standard error:
msDrawMap(): Failed to draw layer named 'ortho_collage'
gdalinfo gives the following:
Driver: ECW/ERMapper Compressed Wavelets
Size is 14610, 11308
Coordinate System is `'
Origin = (1057790.000000,515281.000000)
Pixel Size = (0.50000000,-0.50000000)
Corner Coordinates:
Upper Left  ( 1057790.000,  515281.000)
Lower Left  ( 1057790.000,  509627.000)
Upper Right ( 1065095.000,  515281.000)
Lower Right ( 1065095.000,  509627.000)
Center      ( 1061442.500,  512454.000)
Band 1 Block=14610x1 Type=Byte, ColorInterp=Gray
   Overviews: arbitrary
That's with gdal 1.2.6 - if I try with a recent cvs snapsot, I get the
coordinate info from the .aux.xml file that gets created.
However, if I download one of the ecw files to my local computer and try
to view it using ER Viewer, it refuses to show anything - just black,
and it gives an error and nearly crashes if I try to zoom in.
So, it seems like just plain corrupt ECW are being created. Assuming
this should work, I may have defined the wrong system type in the types
header file (POSIX/LINUX) - how can I get this to work otherwise?
My system is an AMD 64-bit, which I suppose is helping to complicate
things:
Linux dragonfly 2.6.5-1.358 #1 Sat May 8 09:01:26 EDT 2004 x86_64 x86_64
x86_64 GNU/Linux
And I'm using a newly downloaded gcc 3.4.2:
Reading specs from /usr/lib/gcc/x86_64-redhat-linux/3.4.2/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info --enable-shared --enable-threads=posix
--disable-checking --with-system-zlib --enable-__cxa_atexit
--disable-libunwind-exceptions --enable-languages=c,c++,objc,java,f77
--enable-java-awt=gtk --host=x86_64-redhat-linux
Thread model: posix
gcc version 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)
And I'm running fedora core 2.
Anybody have a clue for me?
Thanks in advance.
Chris
