[Gdal-dev] cannot build grass plugin in gdal - still
Maciek Sieczka werchowyna at epf.pl
Mon Jul 18 17:05:55 EDT 2005
> On Fri, Jul 15, 2005 at 08:28:38PM +0200, Maciek Sieczka wrote:
>> Hi
>> Still I can't build the gdal-grass plugin in gdal. I'm following what the
>> README says - and nothing.
<snip>
>> [trawiarz at quercus pkg]$ make
>> make: *** No rule to make target `grass57dataset.o', needed by
>> `gdal_GRASS.so'.  Stop.
>> Where's my error?
> What I do (maybe not ideal, but works):
> You have to link the C files from ../ into the current directory:
> ln -sf ../*.cpp .
> make
> make install
Will try this, thanks Markus.
Does it have to be like this Frank? This makes an average amateur like me
not able to build gdal-grass...
Maciek
