[Gdal-dev] Re: How to separate OGR from GDAL
Mateusz Łoskot mateusz at loskot.net
Wed Jun 1 01:13:41 EDT 2005
Daniel Morissette napisał(a):
> Mateusz Łoskot wrote:
>> Thank you, I'm just going to try MITAB lib.
>> As I see it supports MapInfo formats, but as I understand you
>> correctly, I can take OGR part of MITAG, right?
> You'd need to take the "ogr" and "cpl" directories, and then use that to
> build with OGR's shapelib and sqlite drivers.
OK, I will fight with this this week.
I'll report results here.
>> As I see you are the project leader, right?
> Yup.
Nice, I will catch you sometimes for a little help :-), do you mind?
Regards
Mateusz Łoskot
mateusz at loskot dot net
