[Gdal-dev] Re: Building GDAL with eVC++ 4.0
Mateusz Łoskot mateusz at loskot.net
Wed Jun 1 01:15:30 EDT 2005
Andrey Kiselev napisał(a):
> On Tue, May 31, 2005 at 11:48:41AM +0200, Mateusz Łoskot wrote:
>>>>#ifdef HAVE_LOCALE_H
>>>>#  include <locale.h>
>>>>#endif
>>Certainly, I know that technique but the name "guard" strange for me.
> I didn't read original K&R (i.e. in English), and do not know how they
> call this technique, but Stroustrup uses the term "include guards".
I do not have english version of Stroustrup's book.
I read it in polish, and I haven't met "include guards" term.
Thanks for explanation.
>>evc++ supports nmake build system. Certainly, there are some features
>>in "big" Windows (and "big" namke system) not supported byt Pocket PC
>>SDK. I've created makefile.evc and I'm trying to go with this but it
>>is not enough solution. So, I will try to work with nmake.opt and
>>other files you are talking about. Today I will dig into this job.
> Once I tried to build libtiff using eVC. I do not remember details, but a
> mess with headers was the main problem. I haven't forced enough to
> commit the stuff into libtiff CVS, so all of that remains outside of the
> main tree. I do not think there will be a big hassle to port GDAL to
> eVC.
Yes, I realize that.
> As a first step you should write your own cpl_config.h.evc, because
> cpl_config.h.vc is not suitable for that compiler. Also conditional
> compilation in cpl_vsisimple.cpp and cpl_port.h should be corrected (to
> isolate fcntl.h, for example).
OK, and makefile.evc is also required, I think.
I'll work on this port this week.
Regards
Mateusz Łoskot
mateusz at loskot dot net
