[Gdal-dev] Error in reading gtiff from ERDAS Imagine
Frank Warmerdam fwarmerdam at gmail.com
Fri Jun 10 09:08:14 EDT 2005
On 6/10/05, Juan Cicuéndez <jicicuendez at gmv.es> wrote:
> Hi everybody,
> I am trying to write 1 band DEMS files into a tiff files. Even though the image
> looks ok in pci geomatics and ENVI, it is not possible to load it on ERDAS.
> ERDAS takes de image as 3 band rather of just 1 and when loads the image it
> can't find the band 3. In the past I was using the same code to generate colour
> coded tiff and I had no problems with gdal vs 1.2.1. Now I am on 1.2.6 and I
> was using the option:
> status = GDALSetMetadataItem( poDriver, "INTERLEAVE", "PIXEL", "" );
> Has anyone bumped into this problem? Any advise will most appreciated.
Juan,
I am not sure why this isn't working.  Can you provide me with access
to the GeoTIFF file that isn't readable in Imagine?
Best regards,
