[Gdal-dev] ECW registration information not recognised in ESRI
Jacob Delfos jacob.delfos at maunsell.com
Sun Jun 12 21:58:42 EDT 2005
Frank,
That fixed it. Even though ArcGIS cannot tell the projection, putting that option in makes it look at the coordinate values, and recognises them as degrees.
I would open a bug, but I lost my password, and the password reminders don't seem to arrive.... Is that a problem on my side?
Regards,
Jacob
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: 10 June 2005 21:29
To: Delfos, Jacob
Cc: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] ECW registration information not recognised in ESRI
On 6/9/05, Delfos, Jacob <jacob.delfos at maunsell.com> wrote:
> Have a bit of a mystery:
> I am translating some geotiffs to ecw. These geotiffs have their geographic
> information internally in the headers, as well as in a tfw file. They all
> translate fine, and the coordinate information in the ecw file is recognised
> in ESRI ArcGIS.
Jacob,
I would suggest trying to apply the coordinate system while you are
translating to ECW.  Adding '-a_srs WGS84' on the gdal_translate
commandline should do the trick.
A longer term solution on my part might be to apply a more
appropriate dummy coordinate system instead of RAW if I am
translating data with no coordinate system, but a meaningful
geotransform.  If you open a bug on this issue, I will look into it.
I may need Tom's advise on appropriate fallback coordinate systems
for coordinates that are apparently geodetic or projected.
Best regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050613/f7a0ffb4/attachment.html
