[Gdal-dev] Please try this ECW 3.1-rc2 patch for linux/posix
Bill Binko bill at binko.net
Wed Jun 15 01:20:27 EDT 2005
Sorry, I forgot to say what the problem it fixes is ....
When you run gdalinfo (or anything else that uses an ECWDataset), it hangs
when the destructor gets called about 80% of the time (on my box -- YMMV).
Bill
On Wed, 15 Jun 2005, Bill Binko wrote:
> Hi everyone.
> I found what I think is a problem in the ECW libraries (version 3.1-rc2).
> Basically, they are not initializing a boolean attribute of a class to
> zero (FALSE).  This means that if you test with the debug version of the
> library, it works (GCC initializes it) and if you work with the optimized
> version, it doesn't.
> So, I put together a patch that seems to fix the problem.  I'm attaching
> it to this message.
> Please let me know if this helps, or if there are more occurrences of
> this.  I have posted this to the ERMapper forum, so hopefully, it will
> make it into the 3.1 release.
> Bill
