[Gdal-dev] gdalsplit error on compile with gdal-1.2.6
Marco Vieira marco_vieira at uk2.net
Wed Jun 15 14:46:44 EDT 2005
Bingo!!
 Thank you Frank.
Marco Vieira.
Fone:    + 55 51 9101-1267
> On 6/15/05, Marco Vieira <marco_vieira at uk2.net> wrote:
>> Hi all:
>>    I can compile the Homme Zwaagstra's gdalsplit.cpp with gdal-1.2.0
>> without errors, but when I compile with gdal-1.2.6 I got this error:
gcc -o gdalsplit -L/usr/local/lib -lgdal -I/usr/local/include
>> -I/usr/include -ltiff gdalsplit.cpp -Wall
>> returns:
>> gdalsplit.cpp: In function `CPLErr CopyRasterBand(GDALDataset*,
GDALDataset*,
>>    int, int, int, int, int)':
>> gdalsplit.cpp:237: error: `AddSimpleSource' undeclared (first use this
>>    function)
>> gdalsplit.cpp:237: error: (Each undeclared identifier is reported only
once for
>>    each function it appears in.)
>> Whats happen? The header files appear to be OK.
> Marco,
> I haven't looked at gdalsplit myself, but I would guess that
> it is using the VRTRasterBand.  Relatively recently this
> class was altered so that the AddSimpleSource method
> is on a subclass, the VRTSourcedRasterBand.  Try to
> alter the code to create or cast to this class as appropriate.
> Sorry for not being more specific.
> Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam and
watch the world go round - Rush    | Geospatial Programmer for Rent
