[Gdal-dev] Fwd: [kakadu_jpeg2000] Re: Support for GeoJPEG2000 needed
Julien Demaria dem at acri-st.fr
Mon Jun 20 03:59:35 EDT 2005
Jukka,
I forward you mail to the GDAL's mailing list gdal-dev at remotesensing.org
and more appropriate Geospatial JPEG2000 mailing list
jpeg2000 at remotesensing.org
>Hi Julien,
>One question about GeoJPEG2000: Is it so, that in order to put the
>right information into the uuid box you should first have a valid
>GeoTIFF image?
Yes. GDAL creates a 1x1 pixel valid GeoTIFF in memory and write it to the
jp2 uuid box.
>What about if you only have images already in JPEG2000
>format and corresponding world files, should you in this case first
>convert them to GeoTIFF and then back to GeoJP2?
In this case you have to create the uuid box geotiff from the world file.
GDAL do that if the world file has the same prefix and .wld.
>How about if you
>manipulate GeoJP2 images somehow (subsample, re-project etc.), is
>GDAL taking care of editing the georeferencing data as well?
Yes sure. A GDAL utility gdalwarp do subsample and reprojection and change
the georeferencing as well.
>I have understood that OGC is preparing a GML based solution for
>including spatial reference data in JPEG2000 files. Does anybody know
>if this specification will be ready in the near future?
I think Frank Warmerdam from GDAL is the good person to answer to this.
Regards,
Julien
>Regards,
>Jukka Rahkonen
>--- In kakadu_jpeg2000 at yahoogroups.com, Julien Demaria <dem at a...>
>wrote:
> > At 05:03 17/06/2005, Greg Coats wrote:
> > >Julien,
> > >Thanks for your message, unfortunately it leaves me confused.
> > >Under the heading Building GDAL From Source, External Libraries
>this web
> > >page http://www.gdal.org/gdal_building.html#libraries says that
>GDAL's
> > >JPEG2000 support is based on JasPer.  I suspect this web page has
>out of
> > >date information.  JasPer was superseded about two years ago by
> > >GeoJasPer.  GeoJasPer is fully aware of georeferencing info.
> > >GeoJasPer correctly transcodes between GeoTIFF and GeoJPEG2000
>files.
> > >If GDAL is using GeoJasPer to support GeoTIFF and GeoJPEG2000
>files, then
> > >GDAL does not have to do anything.
> > In fact GDAL support GeoJPEG2000 by several way :
> >          - the first driver is implemented with Jasper :
> > http://www.gdal.org/frmt_jpeg2000.html
> >            but I believe Jasper is less performant than Kakadu (and
>I
> > believe it read ALL the image in memory)
> >          - another driver is based on Kakadu :
> > http://www.gdal.org/frmt_jp2kak.html
> >          - now there is 2 other drivers supporting (Geo)JPEG2000 :
> >                  - with proprietary MrSID SDK which now can
>read/write JP2
> > too (I believe they use Kakadu internally)
> >                  - with the new free ErMapper ECW SDK, which also
>support
> > JP2 http://www.ermapper.com/downloads/download_view.aspx?
>PRODUCT_VERSION_ID=266
> > >A GeoJPEG2000 file begins with the standard JPEG2000 boxes, then
>adds a
> > >uuid box with georeferencing info, and concludes with the usual
>JPEG2000
> > >code stream.  A GeoJPEG2000 file could be made from a JPEG2000
>file by
> > >inserting a uuid box with georeferencing info between the standard
> > >JPEG2000 boxes and the JPEG2000 code stream.
> > Yes I know and I GDAL do that very well : next the part in GDAL
>sources
> > which write the GeoTIFF informations in the jp2 uuid box :
> > /*                       JP2KAKWriteGeoTIFFInfo
> > void JP2KAKWriteGeoTIFFInfo( jp2_target *jp2_out, GDALDataset
>*poSrcDS )
> > /*      Prepare the memory buffer containing the degenerate
>GeoTIFF     */
>file.                                                           */
> >      const char *pszWKT;
> >      double      adfGeoTransform[6];
> >      int         nGTBufSize = 0;
> >      unsigned char *pabyGTBuf = NULL;
> >      if( GDALGetGCPCount( poSrcDS ) > 0 )
> >          pszWKT = poSrcDS->GetGCPProjection();
> >      else
> >          pszWKT = poSrcDS->GetProjectionRef();
> >      poSrcDS->GetGeoTransform(adfGeoTransform);
> >      if( GTIFMemBufFromWkt( pszWKT, adfGeoTransform,
> >                             poSrcDS->GetGCPCount(), poSrcDS->GetGCPs
> >                             &nGTBufSize, &pabyGTBuf ) != CE_None )
> >          return;
> >      if( nGTBufSize == 0 )
> >          return;
> > /*      Write to a box on the JP2
>file.                                 */
> > #ifdef KAKADU4
> >      jp2_out->open_next( jp2_uuid_box_type );
> >      jp2_out->write( (kdu_byte *) msi_uuid2, sizeof(msi_uuid2) );
> >      jp2_out->write( (kdu_byte *) pabyGTBuf, nGTBufSize );
> >      jp2_out->close();
> > #else
> >      jp2_output_box &uuid_box = jp2_out->open_box(
> >      uuid_box.write( (kdu_byte *) msi_uuid2, sizeof(msi_uuid2) );
> >      uuid_box.write( (kdu_byte *) pabyGTBuf, nGTBufSize );
> >      uuid_box.close();
> > #endif
> >      CPLFree( pabyGTBuf );
> > >Given a losslessly compressed, archived GeoJPEG2000 file as input
>to be
> > >transcoded into a lossy GeoJPEG2000 image as output, all JPEG2000
> > >transcoders read the size of the uuid box and then read the
>georeferencing
> > >info.  If the JPEG2000 transcoder is not geo-aware, then it
>essentially
> > >discards the geo-info it just read in the uuid box.  If the
>JPEG2000
> > >transcoder is geo-aware, then it simply copies/writes the geo-info
>into a
> > >uuid box identical to the uuid box it just read.
> > I think a transcoder not geo-aware should copying all jp2 uuid box
>from
> > input to output. It hasn't to know what is it in the box, only to
>copy it
> > to copy the maximum of inputs informations, isn't it ?
> > >Since the Kakadu Software is the basis from many other JPEG2000
> > >transcoders, and frequently updated, it makes sense to include the
>copying
> > >of the georeferencing uuid box in Kakadu, rather than requiring
>each
> > >developer to reinvent this process.
> > Yes I like the idea Kakadu utilities copies the geo information
>from
> > geojp2/geotiff to geojp2/geotiff, why not.
> > >I got the impression from Professor Taubman that several Kakadu
>developers
> > >have already incorporated support for GeoJPEG2000 and GeoTIFF in
>their
> > >products.  If they will publicly document this, then that would be
> > >great.  If not, since I think it is to everyone's advantage to add
> > >GeoJPEG2000 and GeoTIFF support to Kakadu Software, then I
>volunteer to do so.
> > You should see the GDAL source code of the kakadu and geotiff
>drivers.
> > Best Regards,
> > Julien
> > >Greg
> > >On Jun 16, 2005, at 3:44 AM, Julien Demaria wrote:
> > >>Greg,
> > >>If your need is only to read/write GeoTIFF and GeoJPEG2000 you
>should use
> > >>this library/utilities : http://www.gdal.org/ (I send a separate
>copy of
> > >>this post to the GDAL's mailing list).
> > >>It's a "Geospatial Data Abstraction Library" widely used which
>can
> > >>read/write many (~ 50) raster formats in a same generic way.
> > >>GDAL read/write GeoTIFF and has a GeoJPEG2000 driver using the
>Kakadu
> > >>library which allows to read/write GeoJPEG2000 files.
> > >>For example with GAL utilities you can create a GeoJPEG2000 from
>a GeoTIFF :
> > >>gdal_translate -of GTiff geojp2.jp2 geotiff.tif
> > >>the inverse operation is :
> > >>gdal_translate -of JP2KAK -co "QUALITY=10" geotiff.tif geojp2.jp2
> > >>for create a GeoJP2 file (with size 10% of the original file)
>using
> > >>Kakadu library.
> > >>If your really need to implement GeoTIFF geolocation in Kakadu
>TIFF and
> > >>JP2 support, maybe you should also based your work on GDAL
>library.
> > >>But to my mind I think GDAL already do what you want...
> > >>Regards,
> > >>Julien
> > >>At 21:27 15/06/2005, greg_coatman wrote:
> > >>>Professor Taubman has advised me that the Kakadu Software does
>not read
> > >>>nor write
> > >>>GeoTIFF and GeoJPEG2000 images, and he asked me to post a public
>message
> > >>>here.
> > >>>Has anyone documented all of the changes necessary to the Kakadu
> > >>>Software so that it
> > >>>can read and write GeoTIFF and GeoJPEG2000 images?
>For problems with your subscription in this group please email
>kakadu_jpeg2000-owner at yahoogroups.com.
>Yahoo! Groups Links
><*> To visit your group on the web, go to:
>     http://groups.yahoo.com/group/kakadu_jpeg2000/
><*> To unsubscribe from this group, send an email to:
>     kakadu_jpeg2000-unsubscribe at yahoogroups.com
><*> Your use of Yahoo! Groups is subject to:
>     http://docs.yahoo.com/info/terms/
