[Gdal-dev] Compiling ECW JPEG 2000 SDK 3.2 beta
Armin Burger armin.burger at gmx.net
Mon Jun 20 18:48:21 EDT 2005
Bill,
the 3.2 beta is at
http://www.ermapper.com/downloads/download_view.aspx?PRODUCT_VERSION_ID=276
Armin
> I'm sorry, Armin... I thought you were talking about -rc2.
> Could you point me to the download location for 3.2?
> From what Tom responded, my patch will not be in any release for a while,
> so you will probably still need it.
> Bill
> On Mon, 20 Jun 2005, Bill Binko wrote:
>> On Mon, 20 Jun 2005, Armin Burger wrote:
>> > Hi everybody,
>> > I tried to compile the new ECW JPEG 2000 SDK 3.2 beta under Linux. It
>> > compiled without errors (using the 'older system' compilation with
>> > 'NCSNightlyBuildUnix.ksh'), but under the ../bin/linux/ directory it
>> > just created the 'libNCSEcwC.so', not the 'libNCSEcw.so'. GDAL looks for
>> > this file and also the docs say that it should be created. Any clues
>> > why?
>> I found that I had to build with
>> NCSNightlyBuildUnix.ksh release
>> to get the libraries that GDAL needed.  I also HIGHLY recommend either
>> applying my patch or using the debug libraries (built with NCS....ksh
>> debug) and changing the GDALmake.opt files.
>> My patch can be found here:
>> http://forums.ermapper.com/viewtopic.php?p=1630#1630
>> Bill
>> Gdal-dev mailing list
>> Gdal-dev at xserve.flids.com
>> http://xserve.flids.com/mailman/listinfo/gdal-dev
