[Gdal-dev] hdf4 patch for modis 9 product to pick up geometry info...
David Burken dburken at comcast.net
Thu Jun 23 07:55:07 EDT 2005
Hi Andrey,
Andrey Kiselev wrote:
>On Mon, Jun 20, 2005 at 03:04:19PM -0400, David Burken wrote:
>>The following diff allows me to pick up the geometry info from an hdf4
>>modis 9 product.  I'm not sure if this is the best way to do it but it
>>seems to work.
>>I'm also have problems finding another tool that can verify the
>>correctness of the geometry.  ENVI does not pick it up, at least mine
>>trial version anyway.  In ossim it seems to be off in the latitude
>>direction by about nine minutes when swiped against an elevation cell.
>>It's a "sinusoidal " projection.
>>Let me know if you want the whole file.
>Hi, David,
>Could you upload that file? Sorry, but I am not sure I understood the
>logic in your patch, so I would like to take a look at the unsupported
>dataset.
>Regards,
>Andrey
I will send you a link to the two samples.
>PS.
>Please, make uniform patches (diff -u) in the future. They are much
>easier to analyze and apply.
Can do.
Thanks,
Dave
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050623/4d0315b3/attachment.html
