[Gdal-dev] Problems with creating PNG files
Frank Warmerdam fwarmerdam at gmail.com
Tue Mar 1 09:19:24 EST 2005
On Tue, 1 Mar 2005 14:11:51 -0000, Roger James
<roger at beardandsandals.co.uk> wrote:
> I cannot seem to get any sensible output out of the png driver when using
> create_copy
> I made the attached test bitmap and tried it with gdal_translate. The output
> png is broken.
> I am using a CVS source a few hours old and linking against libpng-1.2.6.
Roger,
Your redcross.png is not a PNG file, it is a TIFF file.  You need to use
the "-of PNG" switch on the commandline to select output in png format.
GDAL utilities will not automatically select a format based on the extension.
Instead, they just default to TIFF format.
Best regards,
