[Gdal-dev] configure problem on FreeBSD
Frank Warmerdam fwarmerdam at gmail.com
Wed Mar 2 23:41:19 EST 2005
On Wed, 2 Mar 2005 14:30:37 +0200, John Hay <jhay at icomtek.csir.co.za> wrote:
> Hi,
> I have tried both version 1.2.5 and 1.2.6b3 on FreeBSD and it looks
> like the configure script is using a bash specific feature which
> isn't available in the FreeBSD /bin/sh. It is the two lines:
> if test ${MYSQL_VERSION:0:1} -ge 4 ; then
> if test "${VERSION:0:1}" -lt 2 ; then
> The FreeBSD /bin/sh does not know how to handle the ${variable:0:1}.
> What about rather using a case statement for it? Something like:
John,
Patched as suggested, though it took a few tries to escape the [ and ]
properly since they are spectial quotes to autoconf.  Test on Mysql 3
and 4.
Best regards,
