[Gdal-dev] GRASS/GDAL plugin issue
Markus Neteler neteler at itc.it
Thu Mar 3 14:14:16 EST 2005
after recompiling GDAL from scratch, I no longer get the
GRASS plugin working. What I did:
- compiled GDAL
   ./configure \
    --without-grass \
    --without-libgrass \
- rm -f /usr/local/lib/gdal_GRASS.so
#building GRASS 6.0 plugin support
 cd frmts/grass/pkg/
 ./configure --with-grass=$HOME/grass60/dist.i686-pc-linux-gnu
 ln -sf ../*.cpp .
 make
 make install
 make clean
Now I have
ldd /usr/local/lib/gdal_GRASS.so
        linux-gate.so.1 =>  (0xffffe000)
        libgrass_I.so => /home/neteler/soft/60grass_cvsexp/dist.i686-pc-linux-gnu/lib/libgrass_I.so (0x4000a000)
        libgrass_vask.so => /home/neteler/soft/60grass_cvsexp/dist.i686-pc-linux-gnu/lib/libgrass_vask.so (0x4001a000)
But:
 gdalinfo /home/neteler/grassdata/utm32n/PERMANENT/cellhd/ebergoetzen.rgb
ERROR 4: `/home/neteler/grassdata/utm32n/PERMANENT/cellhd/ebergoetzen.rgb' not recognised as a supported file format.
GDALOpen failed - 4
Local problem or did anything change recently?
I tried on two different machines where things were working so far.
Thanks for any hint
 Markus
