[Gdal-dev] GRASS/GDAL plugin issue
Frank Warmerdam fwarmerdam at gmail.com
Sat Mar 5 11:40:23 EST 2005
On Sat, 5 Mar 2005 12:15:46 +0100, Markus Neteler <neteler at itc.it> wrote:
> Unfortunately it doesn't help yet:
> ls -l /usr/local/lib/gdal_plugins
> -rwxr-xr-x  1 neteler neteler 36993 Mär  5 12:15 gdal_GRASS.so*
Markus,
Sorry for the hassle.  The directory is apparently
/usr/local/lib/gdalplugins, not /usr/local/lib/gdal_plugins.
It is documented deep in the api ref docs at:
  http://www.gdal.org/classGDALDriverManager.html#a8
However, I clearly need better user level plugin documentation.
Best regards,
