[Gdal-dev] tigerpoly.py GetLayerByName
Frank Warmerdam fwarmerdam at gmail.com
Thu Mar 10 12:21:17 EST 2005
On Thu, 10 Mar 2005 11:14:09 -0600, Simpson <asimpson at i-55.com> wrote:
> Greetings,
> I am trying to run tigerpoly.py but keep getting:
>  ./tigerpoly.py TGR06001.RT1 test.shp
> Traceback (most recent call last):
>   File "./tigerpoly.py", line 97, in ?
>     poly_layer = ds.GetLayerByName( 'Polygon' )
> AttributeError: DataSource instance has no attribute 'GetLayerByName'
> Having not a clue about python, is this a data issue?
> Using gdal-1.2.6b3 on Linux 2.4.20-20.8
Drew,
GetLayerByName() isn't a particularly recent addition.
My guesses are:
 o You have quite old Python bindings for GDAL installed
    somewhere and they are getting used instead of the
    new ones.  Try "locate gdal.py" and see if you get any
    surprising items.  Compare the found files to the gdal.py
    in the gdal-1.2.6b3/pymod directory.  Do they match/
 o "ds" is None because the open on the datasource failed.
Best regards,
