[Gdal-dev] Re: GDAL 1.2.6b5 - Release Candidate
uli mueller [geOps] uli.mueller at gmx.ch
Fri Mar 11 11:01:28 EST 2005
Hi Frank
I installed GDAL1.2.6b5 with ECW-support on LINUX. However gdalinfo as
well as gdal in a MapServer application hang when accessing ECW files.
gdalinfo produces the following output (before I have to CTRL-C):
Driver: ECW/ERMapper Compressed Wavelets
Size is 31000, 29000
Coordinate System is:
LOCAL_CS["LOCAL",
     UNIT["Meter",1]]
Origin = (3405500.000000,5327500.000000)
Pixel Size = (0.50000000,-0.50000000)
Corner Coordinates:
Upper Left  ( 3405500.000, 5327500.000)
Lower Left  ( 3405500.000, 5313000.000)
Upper Right ( 3421000.000, 5327500.000)
Lower Right ( 3421000.000, 5313000.000)
Center      ( 3413250.000, 5320250.000)
Band 1 Block=31000x1 Type=Byte, ColorInterp=Red
   Overviews: arbitrary
Band 2 Block=31000x1 Type=Byte, ColorInterp=Green
Band 3 Block=31000x1 Type=Byte, ColorInterp=Blue
The same image on my Windows system with precompiled FWTools caused no
problem.
Thanks for any help
Uli
and my configuration:
# gdal-config --version
1.2.6b5
# gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem
jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk airsar rs2 ilwis
bsb ecw gif jpeg png
# gdal-config --dep-libs
-L/usr3/pkg4/OpenEV_FW_Tree/FWTools/lib -lgeos
-L/home/ulim/downloads/FWTools-linux-0.9.6/lib -lNCSEcw -ljpeg -lpng -lz
-lm -ldl
# gdal-config --libs
-L/usr/local/lib -lgdal
# gdal-config --cflags
-I/usr/local/include
geOps GeoInformatics
D-79100 Freiburg
