[Gdal-dev] relative paths in nmake.opt
Frank Warmerdam fwarmerdam at gmail.com
Tue Mar 15 11:12:19 EST 2005
On Tue, 15 Mar 2005 16:56:36 +0100 (CET), bartvde at xs4all.nl
<bartvde at xs4all.nl> wrote:
> Hi list,
> relative paths e.g. for Xerces don't seem to work in the GDAL makefile. Is
> this intended to work?
Bart,
Generally speaking you should not use relative paths in nmake.opt,
or even unix configures.  The paths are generally used at various
levels in the build tree and so things break down if the paths are
just relative to the root.
Best regards,
