[Gdal-dev] JP2 with MrSid
Kenneth Melero kmelero at sanz.com
Wed Mar 16 11:23:18 EST 2005
Great!!!
-Ken
-----Original Message-----
Sent: Wednesday, March 16, 2005 11:22 AM
To: kmelero at sanz.com; gdal-dev at xserve.flids.com
Subject: RE: [Gdal-dev] JP2 with MrSid
That worked!  Back in action...
Thanks,
Drew.
Sent: Wednesday, March 16, 2005 9:38 AM
To: 'Simpson'; gdal-dev at xserve.flids.com
It'll be lines 1050-1052 and 1101-1105.
You may also need to add the header:   "J2KImageReader.h"
Try that...
-Ken
Sent: Wednesday, March 16, 2005 10:31 AM
OK, I think I saw the lines your referring to, but if you would give me line
numbers, I'll try it on this end.
Thanks,
Drew.
Sent: Wednesday, March 16, 2005 9:21 AM
This is temporary.  I can uncomment and resubmit to the CVS baseline but
would require you to compile your version of GDAL.  This should work.  It is
actually like 2 lines in the mrsiddataset.cpp file.  You can even try it
yourself.
-Ken
Sent: Wednesday, March 16, 2005 10:21 AM
Ken,
Jasper is slow and Kakadu is cost prohibitive.
I guess I'll have to revert back to an earlier release, which is unfortunate
since the latest MrSid code rendering rate of sid files is outstanding.
Should I consider converting all jp2's to a more useable format, or is this
just a temporary condition.
Thanks,
Drew.
Sent: Wednesday, March 16, 2005 9:01 AM
Drew,
Actually MrSID JP2 support is currently commented out.  This was because it
was conflicting with the Kakadu JP2 library and I was trying to figure this
out before turning it back on.  I would suggest using either Jasper or
Kakadu to support your requirements at the moment.
-Ken
Kenneth Melero
Director of Imagery Science
SANZ Inc.
8245 Boone Blvd, Suite 800
Vienna, VA 22182
t 703.442.6630 x19
c 703.577.2333
[mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Simpson
Sent: Tuesday, March 15, 2005 7:45 PM
To: gdal-dev at xserve.flids.com
Subject: [Gdal-dev] JP2 with MrSid
Greetings,
I installed the latest GDAL and MrSid, and am having trouble getting the
command line utilities to work with JP2 files.
#gdalinfo dq2807ne.jp2
> ERROR 1: MrSIDDataset::Open(): Failed to open file dq2807ne.jp2
> GDALOpen failed - 1
The file is from the dq2807.zip archive from
ftp://sjr.state.fl.us/2004_DOQQs/cir/
GDAL      --->  GDAL 1.2.6.0, released 2005/03/13
MRSID sdk --->  Geo_DSDK-4.0.10.720
OS        --->  Linux 2.4.20-20.8
Thanks for any suggestions,
Drew.
Gdal-dev mailing list
Gdal-dev at xserve.flids.com http://xserve.flids.com/mailman/listinfo/gdal-dev
