[Gdal-dev] JP2 with MrSid
Luis W. Sevilla sevilla_lui at gva.es
Wed Mar 16 13:33:24 EST 2005
Using the jpeg200 support in ermapper ECW sdk wodn't be an alternative?
greetings
    Luis
Chapman, Martin wrote:
>FYI,
>I think MrSID JP2 actually uses Kakadu under the hood.  You might ask
>LizardTech.
>Martin
>-----Original Message-----
>From: gdal-dev-bounces at xserve.flids.com
>[mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Kenneth Melero
>Sent: Wednesday, March 16, 2005 9:23 AM
>To: 'Simpson'; gdal-dev at xserve.flids.com
>Subject: RE: [Gdal-dev] JP2 with MrSid
>Great!!!
>-Ken
>From: Simpson [mailto:asimpson at i-55.com]
>Sent: Wednesday, March 16, 2005 11:22 AM
>To: kmelero at sanz.com; gdal-dev at xserve.flids.com
>That worked!  Back in action...
>Thanks,
>Drew.
>From: Kenneth Melero [mailto:kmelero at sanz.com]
>Sent: Wednesday, March 16, 2005 9:38 AM
>It'll be lines 1050-1052 and 1101-1105.
>You may also need to add the header:   "J2KImageReader.h"
>Try that...
>-Ken
>Sent: Wednesday, March 16, 2005 10:31 AM
>OK, I think I saw the lines your referring to, but if you would give me
>line numbers, I'll try it on this end.
>Thanks,
>Drew.
>Sent: Wednesday, March 16, 2005 9:21 AM
>This is temporary.  I can uncomment and resubmit to the CVS baseline but
>would require you to compile your version of GDAL.  This should work.
>It is actually like 2 lines in the mrsiddataset.cpp file.  You can even
>try it yourself.
>-Ken
>Sent: Wednesday, March 16, 2005 10:21 AM
>Ken,
>Jasper is slow and Kakadu is cost prohibitive.
>I guess I'll have to revert back to an earlier release, which is
>unfortunate since the latest MrSid code rendering rate of sid files is
>outstanding. Should I consider converting all jp2's to a more useable
>format, or is this just a temporary condition.
>Thanks,
>Drew.
>Sent: Wednesday, March 16, 2005 9:01 AM
>Drew,
>Actually MrSID JP2 support is currently commented out.  This was because
>it was conflicting with the Kakadu JP2 library and I was trying to
>figure this out before turning it back on.  I would suggest using either
>Jasper or Kakadu to support your requirements at the moment.
>-Ken
>Kenneth Melero
>Director of Imagery Science
>SANZ Inc.
>8245 Boone Blvd, Suite 800
>Vienna, VA 22182
>t 703.442.6630 x19
>c 703.577.2333
>[mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Simpson
>Sent: Tuesday, March 15, 2005 7:45 PM
>To: gdal-dev at xserve.flids.com
>Subject: [Gdal-dev] JP2 with MrSid
>Greetings,
>I installed the latest GDAL and MrSid, and am having trouble getting the
>command line utilities to work with JP2 files.
>#gdalinfo dq2807ne.jp2
>>ERROR 1: MrSIDDataset::Open(): Failed to open file dq2807ne.jp2
>>GDALOpen failed - 1
>The file is from the dq2807.zip archive from
>ftp://sjr.state.fl.us/2004_DOQQs/cir/
>GDAL      --->  GDAL 1.2.6.0, released 2005/03/13
>MRSID sdk --->  Geo_DSDK-4.0.10.720
>OS        --->  Linux 2.4.20-20.8
>Thanks for any suggestions,
>Drew.
  Luis W. Sevilla
  Equipo de desarrollo gvSIG
  Conselleria de Infraestructuras y Transporte
  Generalitat Valenciana
  Valencia - Spain
  http://www.gvsig.gva.es
