[Gdal-dev] UTM to Lat/Long projection
    Frank Warmerdam
    fwarmerdam at gmail.com
    Wed May  4 15:10:44 EDT 2005
On 5/4/05, Ilya Serebrianik <predator2448 at hotmail.com> wrote:
> Hello Frank,
>        Thanks for clearing this up. I am not sure how to project from UTM
> NAD83 to Lat/Long WGS84. In your example application, namely gdalwrap, there
> is a option "+proj=latlong" which would be specified for the -t_srs in order
> to go from whatever the projection of the source into lat and long, I tried
> that and it works, but I do not know how to set this up inside my code, I
> tried using importFromProj4("+proj=longlat"), which should
> automatically set the lat/long option into the srs object I am about to
> assign to the destination image, like this:
Ilya,
And did the example you gave not work? In what way does it fail?
Do the pszSrcWKT and pszDstWKT seem OK?
> OGRSpatialReference oSRS;
>     //oSRS.SetUTM(17, TRUE);
>     //oSRS.SetWellKnownGeogCS("WGS84");
>  oSRS.importFromProj4("+proj=longlat");
I would encourage you to be specific about the datum.  So
you could do:
  oSRS.importFromProj4( "+proj=latlong +datum=WGS84" );
Best regards,
