[Gdal-dev] UTM to Lat/Long projection
Frank Warmerdam fwarmerdam at gmail.com
Wed May 4 15:36:04 EDT 2005
On 5/4/05, Ilya Serebrianik <predator2448 at hotmail.com> wrote:
> Hello Frank,
>        It does not fail in a sense that it crashes, it just doesn't do
> anything to the image as was the case before I added projection to be
> latlong. The pszSrcWKT, and pszDstWKT seem to correct, and the functions
> that compose the latter do not complain either. Here is the code I use, I
> apologize for the mess, don't want to erase experimental lines:
Ilya,
If you boil this down to a simple commandline program with the
filenames hardcoded, and also provide the input data file I will
try and figure out what is happening here.
Best regards,
