[Gdal-dev] UTM to Lat/Long projection
Frank Warmerdam fwarmerdam at gmail.com
Wed May 4 17:18:08 EDT 2005
On 5/4/05, Ilya Serebrianik <predator2448 at hotmail.com> wrote:
> Hello Frank,
>        Sorry for bothering you again. I pasted the code from command line
> version back into the visual c++ version and the same problem, for some
> reason vc++ version does not process the image correctly having exactly the
> same code as command line that works nicely. I could send you my data file
> but it is a 75 MB geotiff.
Ilya,
Sorry, I don't know what to say.  There is obviously some difference
and you will need to figure it out.
Perhaps in the VC++ version the environment is different and the
PROJ.DLL can't be found?
Best regards,
