[Gdal-dev] UTM to Lat/Long projection
Ilya Serebrianik predator2448 at hotmail.com
Wed May 4 22:36:25 EDT 2005
Hello Frank,
       I tried it again at home, in visual studio .net, I fiddled around
with the paths in project settings and indeed by setting every possible path
to GDAL main directory and by putting proj.dll in it as well the image
reprojection worked.
                 Thanks again.
                                Ilya.
>From: Frank Warmerdam <fwarmerdam at gmail.com>
>Reply-To: warmerdam at pobox.com
>To: Ilya Serebrianik <predator2448 at hotmail.com>
>CC: gdal-dev at xserve.flids.com
>Subject: Re: [Gdal-dev] UTM to Lat/Long projection
>Date: Wed, 4 May 2005 17:18:08 -0400
>On 5/4/05, Ilya Serebrianik <predator2448 at hotmail.com> wrote:
> > Hello Frank,
> >        Sorry for bothering you again. I pasted the code from
command line
> > version back into the visual c++ version and the same problem, for
some
> > reason vc++ version does not process the image correctly having
exactly the
> > same code as command line that works nicely. I could send you my
data file
> > but it is a 75 MB geotiff.
>Ilya,
>Sorry, I don't know what to say.  There is obviously some difference
>and you will need to figure it out.
>Perhaps in the VC++ version the environment is different and the
>PROJ.DLL can't be found?
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam,
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
