[Gdal-dev] gdal and mac
James E. Hopper JAMES.E.HOPPER at saic.com
Sun May 8 17:01:37 EDT 2005
I am working on creating a mac framework based version of gdal.  i
havent used the gdal tools before so i wanted to test the framework
version out.  is there a test suite of images etc that i can use to
validate that the framework version works like the library version
created with make?
for instance if i use gdal_translate to convert a geotiff to jpeg i get
Input file size is 4608, 7680
ERROR 4: Failed to open temp.jpg.pam to read.
the output jpeg is fine, but what is a pam file and why am i getting
a failure?
thanks jim
