[Gdal-dev] gdal and mac
Frank Warmerdam fwarmerdam at gmail.com
Mon May 9 10:26:13 EDT 2005
On 5/9/05, Eric Dönges <eric.doenges at gmx.net> wrote:
> Actually, frameworks are IMO more "out of the box" on MacOS X than
> installing
> to /usr/local/ ever could be.
Eric,
My out-of-the-box, I meant it ends up installing differently than
a "configure; make install" from the distributed GDAL source package.
Applications with configure logic setup to look for a conventional
install tree under a normal install tree organization are likely to run
into problems.
Best regards,
