[Gdal-dev] ogr2ogr: Problem with new layer type multilinestring
Möri Cédric Cedric.Moeri at bd.so.ch
Wed May 18 09:49:17 EDT 2005
Hi list
I have a shapefile containing linestrings (polyline) and multilinestrings
(multi-polyline) that I'm trying to put into a PostGIS-DB using ogr2ogr.
The problem is, that it always violates the check constraint geometry type.
If I try it without the -nlt option, the geometry column is "linestring"
and, of course, the multilinestring-objects violate the constraint. If I put
the -nlt option to "multilinestring" the linestring objects violate the
constraint too.
I thought, that, if the -nlt option is set to mulitlinestring, it forces a
conversion of linestring objects to multilinestrings as it does it with
polygons/multipolygons.
Am I wrong or whatelse may be the issue?
I am using ogr2ogr version 1.2.5.
regards
mit freundlichen Grüssen
Cédric Möri
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Abteilung SO!GIS Koordination
Rötihof
CH 4509 Solothurn
T:   ++41 (0)32 627 2475
Fax: ++41 (0)32 627 2214
mailto:cedric.moeri at bd.so.ch
http://www.sogis.so.ch
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050518/d9c06e5b/iso-8859-1QMF6ri_CE9dric2Evcf.obj
