[Gdal-dev] VRTWarpedDataset w/ -dstalpha
Frank Warmerdam fwarmerdam at gmail.com
Fri May 20 14:34:06 EDT 2005
On 5/20/05, Dardo D Kleiner - CONTRACTOR <dkleiner at cmf.nrl.navy.mil> wrote:
> I've found that if I 'touch' the dest?.8888 file before warping (without
> specifying "-of vrt"), I get the following error:
> "ERROR 5: Destination band 1 appears to be read-only."
> If I don't specify "-of vrt", even though the output already exists it gets
> overwritten as a GeoTIFF file.
Dardo,
Hmm, this sounds like a bug.  If you can submit sufficient details in Bugzilla
I would hope to dig into it.
Best regards,
