[Gdal-dev] FW Tools file selection
Wed Nov 2 19:18:02 EST 2005
On 11/2/05, Robert Waterman <rwaterman at digitalglobe.com> wrote:
> I am currently working with FWTools0.9.8.  I have built a couple of tools to
> add to the OpenEV viewing environment.  It seems that the version of gtk
> that this is built on does not support the multiple file selection method in
> FileSelection nor does it support the class ListStore.  Does v1.0.0a5
> support these?  If not, is there a solution which would allow me to
> implement these methods/classes?
Robert,
I haven't changed the GTK version since starting the FWTools
releases. I would suggest you ask on the openev-discuss list
where others might have suggestions.
Best regards,
