[Gdal-dev] ArcMap overview AUX files
Sheykhet, Rostic rsheykhet at sanz.com
Thu Nov 3 13:58:41 EST 2005
Frank,
Are there any particular files that I can just patch the 1.3.1 release
with?
Thanks,
Rostic
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of
Frank Warmerdam
Sent: Thursday, November 03, 2005 8:24 AM
To: Sheykhet, Rostic
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] ArcMap overview AUX files
On 11/2/05, Sheykhet, Rostic <rsheykhet at sanz.com> wrote:
> Hi all,
> There appears to be a problem with using ArcMap-created .aux files as
> overviews.
> When I execute the sample test case below, I get an access violation
on
> Windows and a segfault on unix.
> This problem has been verified with the
> http://www.gdal.org/dl/data/gtiff/utm.tif file.
> I am attaching the .aux file generated for the utm.tif so that this
can
> be tested without ArcMap.
Rostic,
I have verified that this problem is corrected in CVS.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
