[Gdal-dev] gdal 1.3.1 and Terra ASTER hdf files
Michael Barton michael.barton at asu.edu
Thu Nov 3 19:29:04 EST 2005
I work with the GRASS GIS project and haven¹t been able to import and
georeference Terra ASTER hdf files since gdal version 1.2.6. I recently
compiled and installed the most recent 1.3.1 (as of last week) and it still
produces errors (see below). As an update, I just tried r.in.gdal from GRASS
6.1 cvs and it will not import the ASTER files either. First it did not
recognize the projection, so I set the override projection flag. Then it
won¹t recognize a band number or import all bands (default).
So, back to my original question, what has changed since 1.2.6 that keeps me
from importing ASTER¹s? Could this be fixed?
Thanks much
Michael Barton
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Thu, Nov 03, 2005 at 09:02:00AM -0700, Michael Barton wrote:
> I tried to import Terra ASTER hdf files using the latest gdalwarp and my
> r.in.aster script last week, after compiling the latest version (1.3.1) of
> gdal. It still gives an error that gdal cannot read the projection info in
> the ASTER hdf's. This has been an issue since 1.2.7 (version 1.2.6 still
> works fine on my Mac).
> I haven't tried r.in.gdal, but suspect that I'd have similar problems
> (please correct me if wrong!).
> Is there a fix or workaround to this? All ASTERs are in WGS84, UTM
> projection (the zone varies of course).
> Michael
> USA
> > From: Hamish <hamish_nospam at yahoo.com>
> > Date: Thu, 3 Nov 2005 14:44:44 +1300
> > To: Jonathan Greenberg <jgreenberg at arc.nasa.gov>
> > Cc: <GRASSLIST at baylor.edu>
> > Subject: [GRASSLIST:8849] Re: HDF files?
> >> Is there any way to get HDF files into GRASS?  I saw there is an
> >> r.in.hdf command, but Grass 6.0.1 on MacOS X is throwing and error
> >> when I try it: command not found
> > Use r.in.gdal, but GDAL must be built using the --with-hdf4 switch.
> > http://www.remotesensing.org/gdal/frmt_hdf4.html
> > try "gdal_translate --formats" and check for:
> >   HDF4 (ro): Hierarchical Data Format Release 4
> >   HDF4Image (rw+): HDF4 Dataset
> > or just "gdalinfo <dataset>" and see if it understands the file(s).
> > "r.in.gdal -f in=dummy out=dummy" will also list supported GDAL formats.
> > (often there will be about 50 of them)
> > Hamish
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051103/3ea0fe48/attachment.html
