[Gdal-dev] Java library for reading ESRI shapefiles?
Chapman, Martin MChapman at sanz.com
Tue Nov 8 17:18:24 EST 2005
www.openmap.org has some shape file classes, although, if you get the
shape file white paper off of esri's website it's fairly straightforward
to parse the files directly.  You can see how they do it in openmap.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Tim Beckmann
Sent: Tuesday, November 08, 2005 2:42 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Java library for reading ESRI shapefiles?
Does anyone know of a freely available Java library for reading ESRI
shapefiles?  The gdal ogr and shapelib code has been great in the past,
but now I have a need to read ESRI shapefiles directly from a Java
applet.
Thanks
Tim
Tim Beckmann
Software Project Lead
Science Applications International Corporation (SAIC)
Contractor to the USGS/EROS
Sioux Falls, SD 57198
605-594-2521    Phone
605-594-6940    Fax
tbeckman at usgs.gov
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
