[Gdal-dev] Q
Eric Dönges eric.doenges at gmx.net
Thu Nov 10 07:54:03 EST 2005
Am 10.11.2005 um 10:32 schrieb Tim Sutton:
> Hi
> Take a look at qgsrasterlayer.cpp in the QGIS (http://qgis.org)
> source code. We have already solved this problem.
> Essentially, assign each of the three bands pixels to a different
> variable, then create a qcolor using each as the r,g,b values. Then
> simply paint your pixel using that qcolor.
> OT I would be intersested to chat to you to see if a) the
> application you are working on is open source and b) you would be
> interested in combining efforts with QGIS.
> Best Regards
> Tim
> On 10 Nov 2005, at 08:42, t.laue at web.de wrote:
>> Dear all,
>> I am currently developing a small application using Qt 4 and C++
>> for handling and
>> evaluating large aerial images given in TIF / TIFF format. I am
>> using GDAL for image
>> input. I am working with image overviews and image tiles for
>> providing a good zoom
>> and pan performance.
>> At the moment GDALRasterBand::RasterIO is being used for accessing
>> overview levels
>> and reading small image patchs because I did not find a way how to
>> read from single
>> overview levels using GDALDataset::RasterIO. Everything is working
>> fine as long as I
>> am utilising gray value images with one raster band.
>> In the case of RGB images I can employ a loop for retrieving the
>> data of all three raster
>> bands from the same overview level resulting in three buffers
>> which contain the data. I
>> would like to display the color image at the screen but I have no
>> idea how to combine
>> them again.
>> Is there a way to create a new dataset for adding the data read
>> from different bands? Is
>> it possible to use GDALDataset to access single overview levels?
>> Do I have to use
>> another method independent of GDAL to bring the three buffers
>> together in order to
>> recreate a RGB image patch? Is anyone working with Qt 4 and GDAL?
While RasterIO doesn't let you specify which overview to use
directly, I believe it
automatically calculates the most appropriate overview to use based
on the source and
destination image sizes you specify to RasterIO. The big advantage of
using RasterIO
is that you can have RasterIO worry about creating packed pixel
formats from the color
bands, which should be a lot faster than the method Tim suggests
above. This is how I
do it:
// Now, copy the raster data from the dataset.
if (CE_None != GDALDatasetRasterIO(_dataset, GF_Read,
                                    x, y, (int)ceilf(rect.size.width),
                                    (int)ceilf(rect.size.height),
                                    data, width, height, GDT_Byte,
bands,
				   &_bandMap[bandStart],
				   bytesPerPixel, bytesPerRow, 1))
	NSLog(@"problem with GDALDatasetRasterIO");
         goto done;
'data' is the pointer to the memory area that should hold the ARGB32
data, 'bands' is
the number of bands in the dataset, and '_bandMap' holds an array of
the indexes of the
bands in the correct order, which is alpha, red, green and blue for
my application.
The 'bandStart' parameter is used to handle cases were the dataset
doesn't have an
Alpha channel, in which case it is 1 instead of 0 (this allows me to
simplify the code
that generates the _bandMap). bytesPerPixel is 4. Read the RasterIO
documentation
for more details.
Disclaimer: I've never worked with QT before, so the above may be
totally useless to
you.
With kind regards,
Eric
